W130/W30 website blocking capability
  • September 24, 2023
  • 87 views
Hello,
Is there any way to be able to block specific websites from a W130/W30 AX7800 mesh router? I have looked everywhere in the app and could not find it. Also, I wish there was a way to manually place a bandwidth limit speed per device as my kiddo is eating all of it watching streams, even when he's set to the minimum of "normal" per the app.
Hello Maz
                   On the SBC app you can only check for options that are available on the parental control setup using below link so please have a look on it and there is no option or configuration available on the app to setup speed limit or bandwidth limit speed as per device.
                  http://arris.force.com/consumers/articles/General_FAQs/mAX-Routers-Parental-Control-Setup
Hello Maz
