W31 backhaul
  • March 15, 2026
  • 9 views
W31 doesn’t change to wired backhaul after connecting Ethernet cable from main router lan port to satellite lan port. Surfboard central application still shows wireless connection speed between the two W31 units and the main unit does not show the satellite in the Ethernet connected list.
For wired backhaul to work correctly, connect an Ethernet cable from the main router’s LAN port to the satellite’s WAN port.
