W31 Changing WiFi Channels
  • May 5, 2025
  • 98 views
I’m using a W31 as my WiFi router with 2 W31 satellites.  All three are using channel 11 for the 2.4GHz band which is causing a great deal of signal interference.  How can I change the channel?
Unfortunately, the W31 MAX Pro does not offer an option to change the Wi-Fi channel.
Just to clarify, the system you have set up with the main router and satellites is not of three separate routers.
They operate on the same network. This means that any settings changed on the main router will also apply to the satellites, as they sync with the main router. Ideally, the main router plays the primary role, while the satellites extend the main router's frequency.
Make sure you check how many devices are connected to the 2.4GHz network, as a high number of connected devices can lead to interference.
To minimize interference, keep your router away from electronic devices such as microwaves, cordless phones, and baby monitors etcetera
