W31 remote management
  • January 19, 2024
  • 154 views
Should I be able to change port  forwarding and such from out side my LAN.  It says I’m connected, can go in and edit items, but when I save them it’s not updating them.   And why oh why can I no just connect to a web page to be able to manage my router like 99.9% of every other router out there?
Outside LAN changing router configuration or port forwarding is not possible.
You can set up only through inside the network .
Outside LAN changing router configuration or port forwarding is not possible and when you are inside the network is not saving or outside the network is not saving?
  • January 24, 2024
Outside…  So why even connect outside the network if you cannot make changes?
And I’m sure there is no way to set up a DMZ for one IP address is there?  Wanting to set up a few game servers and would be easier just to open this computer up to all ports and handle security on it.     Like I said, my mistake for not doing more research that’s for sure.. That was a waste of lots of money for something so limited.. Guess that’s why amazon has them for $250 now..   oh well..
