Arris Surfboard Ax6600 Wall Plug Satellite not registering
  • June 1, 2023
  • 154 views
I keep getting this error; 000-2207. I have tried every simple solution to fix this; moving the satellite closer, doing a factory reset, restarting the main router, even deleted the app and redownloaded it. I am quite literally out of solutions before I return this device.
Hello KTeal4,
As you have tried most of the steps like  moving the satellite closer, doing a factory reset, restarting the main router, even deleted the app and redownloaded it,
Try to reinstall the app and if you get the same error code:000-2207: Solution is to wait at least 1 minute then click the Try again button.
Hello KTeal4,
