ARRIS SURFboard mAX connectivity issue
  • November 2, 2024
  • 138 views
When I try to access my ARRIS SURFboard mAX router, I get the following message:
“The device or resource (the local IP-address for the router) is not set up to accept connections on port “HTTPS”.  I have been using the IP-address or xxx.xxx.xxx.1 on my local network.  Is that correct?  If not, what address should I be using?  If it is, how do I correct the issue?
Best answer by Netopia
The mAX routers doesn’t have Web access. You’ll need the SURFboard Central app for first time setup and to manage the router.
Forum|alt.badge.img+30
  • Rockstar!
  • November 5, 2024
  • November 6, 2024
Thank you, Netopia.  I had forgotten that’s what was needed.  I do have the app loaded and was able to take care of my problem.
