Bridge Mode
  • May 27, 2022
  • 208 views
Where the Wild Pings Are
Cable Modem Commandos
Forum|alt.badge.img+9
What is Bridge Mode for and when should I use it?
Best answer by Arcangelmk
Bridge mode is typically used when you have another router in front of your mAX setup, providing a DHCP server/IPs.  This would typically disable routing functionality and allow your main router to perform routing tasks, essentially turning your mAX units into satellites or wireless switches.
  • May 27, 2022
