If I connect my satellite to main main with a really long Ethernet cable, will this give me a faster connection?
Connecting Satellite with Ethernet
Best answer by Anonymous
It depends on your setup. You will be capped at 1 Gbps with Ethernet connection. The BackHaul connection (Wi-Fi connection between the mAX main and satellite) can achieve up to 4.8 Gbps.
You can check the SURFboard Central app to determine the BackHaul speed of your current setup and determine if the Ethernet connection is better for you.
