how do i secure the onboarding wifi network
  • October 17, 2025
  • 136 views
when setting up my network, there are instructions to allow the "SURFBoard-Onboarding' wifi network and then to add a second secured network. i would like to secure them both. how do i do this?/
It appears that you have two W21 routers. Could you please confirm the LED light status on both devices?
Also, please note that Surfboard Onboarding is a setup Wi-Fi network that gets broadcast when you're in the process of setting up the W21 routers.
  • October 17, 2025
Are you referring to the guest network? What are you actually seeing?
Could you please confirm your product’s model number?
  • October 19, 2025
SURFboard mAX® Mesh Wi-Fi® 6 System  with the S33 modem.
the guest wifi is secure. the  onboarding one does not have any security and no option to add it...
