Setup my mesh system, no hassles first week. Modem SB8200 and router in office, EOP from router to satellite for basement coverage. And EOP switches for two TV’s to reserve WiFi bandwidth for other devices. Everything was working great. Came home and WiFi network is down, couldn’t get it to come back online even though I was getting service when plugged into the modem. Deleted “devices” from Surfboard app and tried to add the router and satellite back on, but can’t get to the setup process again, “onboarding WiFi” doesn’t appear after deleting router and satellite from the app and trying to go through the configuration again. Router is plugged into modem, was able to join my original WiFi network that I setup, but the w121 doesn’t appear as a device in my app anymore even though I’m connected to it.
network reboot, router and satellite not on app - W21
You cannot access the router's app if you set up the primary modem and router using the same email address.
I advise you to either reset the app's configuration using a different email address or to remove the device from the SB8200 app and add the max router.
