Remote Access
Where the Wild Pings Are
Cable Modem Commandos
Forum|alt.badge.img+9
Can I control/configure my mAX 121 remotely?
Best answer by rangerlg
Should be able to with the surfboardMAX app.
  • May 27, 2022
  • Button Mashers
  • June 1, 2022
Hello, hope you are doing fine.
You can manage you router´s settings remotely. That could be done through the Surfboard Central app.
Hope this could help you
  • August 17, 2022
Hi, just avtivated my G36 but my remote desktop and printer will not connect. What need to be change in the cinfiguration settings?
  • August 18, 2022
@lbustillo You might start your own thread instead of jumping in on the remote access thread about a different device. You  might put more details such as what your desktop/printer models are and the error you’re getting when you try to connect them.
