How do I enable only 2.4 GHz on my SURFboard W21 mesh router, I’m trying to install my Arlo doorbell chime. And it needs to install on 2.4 GHz. Thank you for your help!
SURFboard W21 mesh router- enabling 2.4 GHz
On the home screen of the surfboard central app under network setting you can see the following option
Main networks
Guest networks
Extended wifi settings
Select Extended wifi setting to disable the band steering option then
select Main network and there you can see Band steering option again disable that too then you can see both 2.4 and 5G network on the app.
