Switch for S33 - W21 setup
Need a 5 port switch for S33 - W21 setup. Recommendations?
Pretty much any unmanaged gigabit switches will work fine.
Just make sure to attach the switch to the w21 and not to the modem.
  • 2298 replies
  • March 4, 2024
  • March 4, 2024
Thank you. Good to know not to connect to modem as that was my plan.
  • March 4, 2024
Ok I'm home now. Do I connect S33 to WAN port on W21? Then LAN port on Same W21 to switch. Do I need to change anything in Surfboard Central app?
  • 2298 replies
  • March 5, 2024
Yes. That's how you do it. Shouldn't need to change anything if you have an unmanaged switch
  • March 5, 2024
All connected and working well. Thanks for your help. 😊
  • 2298 replies
  • March 5, 2024
Glad its working!
