W121 LED Settings: Slider does not change brightness
  • July 23, 2023
  • 132 views
I installed the W121main and satellite units yesterday. On both the main and the satellite units, the LED settings slider does not change the brightness. I have the app installed in two places, on an IPhone and IPad and neither slider will change the brightness.
Hello Bauseeric
                           In this case you can have a  try on the steps mentioned on the below article to check whether you can adjust the router LED light brightness using the surfboard app
                           http://arris.force.com/consumers/articles/General_FAQs/mAX-Routers-Adjust-LED-Ring-Brightness
Hi Bauseeric,
As you are facing difficulties with the LED settings slider on both the main and satellite, let's check on these :
  • May I know when did you first do the onboarding of the SURFboard App
  • Was the LED slider working before or  is this the first time you are noticing it
  • Could you try changing the LED on your iPhone after disconnecting from the max SSID
  • Could you update the W21 Firmware and also the Firmware of the iPhone and iPad
  • Have you done the factory reset on the Router
Please confirm this and contact us if you have any other queries.
  • August 7, 2023
Restarting the app got the brightness adjustment to work one time.  Each time I need to change the brightness, I need to restart the app. The actual change in brightness is not that great; it would be better if the blue light could be turned off completely.
Hello Bauseeric
