Is there any way to make the satellite function as a main router? Arris should just allow access via browser (192.168.0.1) so that it can be setup that way. This would simplify the whole process. The app just complicates everything. With TP Link not being recommended, Arris has a chance to emerge as a good option, but the setup needs to be better. If each router has the same innards, why not just treat each as the same and have the selection for main or satellite?
The W161 system is designed with a designated main router and satellite, meaning the units cannot be swapped.
Additionally, there is no option to access the GUI interface for any MAX routers from Arris.
To activate the W161, please use the SBC app. You can refer to the links below for setup instructions:
We use 3 different kinds of cookies. You can choose which cookies you want to accept. We need basic cookies to make this site work, therefore these are the minimum you can select. Learn more about our cookies.
