ARRIS modem
  • May 2, 2025
  • 43 views
Under what name Arris Surfboard will appear when I connect to xfinity services
Are you referring to the network names being broadcasted? If so, and if your product is a gateway (modem/router), you can find the SSID and password at the bottom of the device printed on a label.
To provide you with precise information, could you please share your product’s model number?
