Arris SBG7600AC2 No wired internet
  • January 22, 2025
  • 6 replies
  • 140 views
After a recent Xfinity outage I am unable to connect to the internet using my desktop which has an ethernet cable plugged in the back of the modem. I can connect wirelessly on my laptop. I have tried two different desktops, three ethernet cables and all four sockets in the back of the modem. The error message on the computer is that the device does not have a valid IP configuration. I have reset the IPv6 and IPv4 addresses automatically, and also typed them in manually but the computers still cannot identify the modem. Thank you
Since the problem persists even after the suggested troubleshooting steps and for further assistance, we kindly recommend visiting us at www.arris.com/consumersupport
Could you please help us with the model number of your product?
Please try using different Ethernet cables, swap the ends of the cables, and make sure the LED lights on the Ethernet port of the gateway are flashing.
  • January 23, 2025
Thank you - SBG7600AC2
I have used three different ethernet cables (including the two that were working fine before the internet outage).
The light on the computer flashes but that at the modem/router is lit but not flashing
The modem and computer have been rebooted several times
Thank you for the update!
Please try switching ethernet ports on the SBG7600AC2.
I would suggest you try disabling the Ethernet port and then enabling it again by logging into the interface of the SBG7600AC2.
Since the wireless connection works, connect to the network, open a browser, and enter http://192.168.0.1 in the address bar.
Please refer to this link, where you can find the steps to log in to the interface.
http://arris.force.com/consumers/articles/General_FAQs/SBG7600AC2-Web-Manager-Access
After logging into the dashboard of the interface, select 'LAN Setup' at the top, then choose 'PORTS' under the subcategory.
Next, select the port, uncheck the 'Enable' box, apply the settings, and then follow the same steps to enable it again.
Please repeat these steps for all other ports.
  • January 27, 2025
I had high hopes for the “disabling” suggestion but, having dome all four ports and tried plugging the ethernet into each of them, the problem remains the same
The light is on (stable) at each end of the cable but the computer still cannot identify the network
  • February 8, 2025
Noted - thank you
