Cable Modem which supports Euro Docsis 3.1
  • July 18, 2024
  • 120 views
I am looking for a cable modem supporting EuroDocsis 3.1 , min 1 Lan port and preferably (but not required) 1 fon port. It should not have an integrated router. Are there modems like that here? I am just unsure if “Docsis 3.1 ……… Supporting all major Cable Providers” means globally or US only.
We do have cable modem with Docsis 3.1 compatibility model SB8200 and S33, T25 is also a cable modem with vo
ice port and that is compatible only with Xfinity. You can check for the modem features and specifications on shop.surfboard.com and also we would suggest you to check for the modem compatibility with your service provider.
