Change Default WiFi settings
  • July 22, 2025
  • 62 views
I am using the default 2.4G SSID and password.  How do I change them to my desired WiFi name and password?
Could you please help us with your product's model number?
  • July 22, 2025
DOCSIS 3.1 WiFi Cable Modem
That is not the model number. The model number normally is located on the front panel of your ARRIS unit, just below the lights normally our model numbers start with “SB”, “SBG”, “SBR”, “SVG”, “SBV or “G”
For your information, DOCSIS (Data Over Cable Service Interface Specification) is an international telecommunications standard that enables high-speed data transfer over existing coaxial cable infrastructure.
