Compatible Arris modem/router for TDS uses.
  • October 18, 2023
  • 1486 views
TDS uses arris DG3452 but you can't buy it only lease it from TDS.  What is the comparable Arris modem/router that a consumer can?
Best answer by LoveMyLab
Based on what I am reading, the TG3452 includes telephony. If that is something you need, things get a little more challenging. Most ISPs provide a list of compatible modems. I don’t see anything authoritative at TDS. Some ISPs will not allow 3rd party modems if telephony is required.
I would only get a modem that is DOCSIS 3.1. If you want voice and WiFi in a single unit, I don’t see anything that is available at retail at the moment when I look at XfFinity that gives you everything in one unit.
https://www.surfboard.com/products/xfinity-voice/t25/
https://www.commscope.com/product-type/broadband-video-devices/broadband-devices/docsis-3.1-gateways-modems/tg3452/
LoveMyLab
Guardians of the Gateways
Forum|alt.badge.img+19
  • Guardians of the Gateways
  • October 18, 2023
Are you certain that’s the correct model number?
  • October 18, 2023
Oh it's TG3452.  Only available for leasing through TDS so I'll look into the model you mentioned.  Thank you.
LoveMyLab
  • October 19, 2023
