Compatible speed for ARRIS TM1602A
  • October 3, 2023
  • 752 views
I upgraded to 1GB speed with Optimum. Will my current TN1602A be able to support the 1GB speed?
Best answer by LoveMyLab
If phone service is no longer required, I would think the SB8200 would be a good choice. Price was down to under $120 at Best Buy recently, but has gone back up. The challenge is, I haven’t yet found a comprehensive list of supported modems on the Optimum site. You may have to call/chat with them to get the correct link to the latest supported devices.
LoveMyLab
Guardians of the Gateways
Forum|alt.badge.img+19
  • Guardians of the Gateways
  • October 3, 2023
I would say it is doubtful. It is DOCSIS 3.0 and appears to be 16/4. Do you still need the phone access?
https://www.optimum.net/pages/optimum-certified-modems.html
  • October 3, 2023
No, phone service is no longer required.
LoveMyLab
  • October 3, 2023
