I upgraded to 1GB speed with Optimum. Will my current TN1602A be able to support the 1GB speed?
Compatible speed for ARRIS TM1602A
Best answer by LoveMyLab
If phone service is no longer required, I would think the SB8200 would be a good choice. Price was down to under $120 at Best Buy recently, but has gone back up. The challenge is, I haven’t yet found a comprehensive list of supported modems on the Optimum site. You may have to call/chat with them to get the correct link to the latest supported devices.
