DG3450
  • October 4, 2023
  • 59 views
Hello, how do I change the WiFi name for my DG3450?
Best answer by LoveMyLab
My understanding is that device is provided by your ISP and they should have instructions for you. I don’t believe Arris provides direct support.
I did find the following from Americable and it looks like it should cover everything you need.
https://kb.americable.net/knowledge-base/arris-dg3450-changing-the-wi-fi-network-name-and-network-password/
LoveMyLab
Guardians of the Gateways
Forum|alt.badge.img+19
  • Guardians of the Gateways
  • October 4, 2023
  • October 4, 2023
Thank you for this information.  I wondered if it were perhaps something my ISP would need to do.  I appreciate it!
