forgot password model DG3450
  • October 5, 2023
  • 362 views
Trying to login to my Arris router model DG3450. It keeps saying invalid credentials. How to I reset it.
Best answer by LoveMyLab
I believe that is an ISP specific version, so you’ll need to reach out to them if you need detailed instructions. The reset is done via a small button on the back that will need a paperclip or SIM card ejector or something similar. Here’s a link from one ISP that may help.
https://midco.com/contentassets/6019e0018ebc4f97bfbdc527941277e2/setup_guide_arris-dg3450_wireless_modem.pdf
LoveMyLab
Guardians of the Gateways
Forum|alt.badge.img+19
  • Guardians of the Gateways
  • October 5, 2023
