I got a new SURFboard modem and connected everything but I can’t get online. I was told that the modem needs to be activated, can someone help with that?
How do I activate my new cable modem?
Best answer by mAX SURF
The easiest way to get started is to download the SURFboard Central mobile application.
The App will give you a step-by-step guide to install your device, including direct use of the self-help Service provider portals (for applicable Service providers) so you may not have to call in at all.
