how do i find the network number and passphrase after my internet is hooked up and modem is activated
  • October 9, 2023
  • 131 views
How am I able to find the number and pass phrase that is needed to connect to internet
Best answer by LoveMyLab
What is the model number of the device you are using? If it is an SB8200, and you want to access the console, you use ‘admin’ and the last 8 digits of the SN on the lable on the device. You don’t need any login to access the internet.
LoveMyLab
Guardians of the Gateways
Forum|alt.badge.img+19
  • Guardians of the Gateways
  • October 9, 2023
