How do I test Ethernet ports
  • July 17, 2024
  • 43 views
How do I test Ethernet ports?
You can see light flashing or blinking on the ethernet port when you connect ethernet cable or LAN cable to the modem LAN port. If that is not working need to check using different ethernet cable for testing.
