how to keep connection from sleeping?
  • January 14, 2024
  • 36 views
I have an AppleTV and a few computers wired to a switch and then the switch is wired to my base. How can I keep the connections from sleeping even if the connected device goes to sleep (like at night, etc).Sometimes the AppleTv is hard to wake up with the remote
​​​​​There isn’t much to do. They’re designed that way. You could potentially go into the settings on the apple and change it to prevent standby
  • January 14, 2024
