ip asdress
  • September 21, 2025
  • 76 views
My internet provider says I need to set up the WIFI ip address for my wifi router. How do I do that?
Could you provide the model number of your product?
  • September 26, 2025
Details are key. A model helps. Because we see al the time where users are trying to setup wifi on a modem only device. Plus each model has different methods.
You can find manuals on the support site when you select your device.
https://www.surfboard.com/support/resources/
