Modem w/ phone gateway
  • August 30, 2024
  • 10 views
Is there a more current model to the TG2472G ?  need a modem with one or two phone ports.
with or w/o wifi.
thanks!
T25 is a cable modem without Wi-Fi and has 2 telephone ports.
SVG2482AC is gateway which is the combination of modem and router, with Wi-Fi and has 2 telephone ports on it.
Both the above mentioned models are compatible only with Xfinity. You can check for product details and specifications on shop.surfboard.com
