Network and Password sb6121
  • January 9, 2024
  • 374 views
In order to get a service from Xfinity I would need el Network Namen and Pasword of my modem. Given that the modem is Motorotola I asked them about that.  Motorola sent me an email telling:
“Based on the MAC address provided, the device appears to be an Arris modem. The older Motorola modems, the Surfboards, were manufactured by them.
Please reach out to Arris's customer support for further assistance with addressing the issue you're experiencing with your modem: https://arris.my.salesforce-sites.com/consumers/ConsumerProductSupport.
The information printed on the bottom label:of the modem is:
SURFboard Model: SB6121
Thank you.
FCI:001
Thank you.
SB6121 is just a cable modem so its just a plug and play device without inbuilt WIFI on it. so you can access WIFI only on by connecting separate router to the modem and you can get the WIFI credentials on the router label.
