online light steady blue, wifi light wont connect
  • October 22, 2023
  • 98 views
The router light/ online is on, but it won’t connect to the wifi light. I did have a power surge throughout the day
What device do you have?
You mean the wifi light is off?
A little better description helps.
Did you try a factory reset?
  • October 23, 2023
