Pairing 2 VAP2404 devices through WPS button
  • June 3, 2024
  • 103 views
Hi,
I would like to pair again 2 VAP2404 devices independantly from my Internet Box. Is it possible ?
Those 2 units were originally paired out of the factory.
Suddenly, for an unknown reason, there were no Wifi signal coming out of the Access Point one.
I decided to reset the 2 units to factory settings using the Reset button.
Then I tried to pair them again using the WPS buttons.
Is that right ?
Apparently it does not work.
What can I do ?
Many thanks for some help
VAP2404 is not supported by Arris. Arris supports only the retail products that are available on surfboard.com but not the ISP lease products.
