My sbg6700ac modem router has always disconnected from various brands of printers,c printer is only 3 ft away ..
thanks
View originalMy sbg6700ac modem router has always disconnected from various brands of printers,c printer is only 3 ft away ..
thanks
View originalFor this issue we would suggest you to try connecting printer to the 2.4 network and also change the security mode on your wifi settings to most compatible one which is WPA/WPA2-PSK(TKIP/AES) and save setting. please follow the steps mentioned below to make the changes and try with the connection.
Launch a web browser, such as Internet Explorer, Firefox, or Safari. Enter http://192.168.0.1 into the address box. The Login page will appear.
