problem with user name password
  • February 24, 2023
  • 101 views
Hello , i can't login the username and password aren't "admin" and "password".
Where can i find the serial number ?
Thank a  lot
  • 2275 replies
  • February 24, 2023
the serial number should be on the label.
What device do you have?
Did you already set it up? Because when you set something up, it usually requires you to change the password during setup
