recommend for 1G Mediacom cable
Top pick for Mediacom 1g connection. Currently have a Surfboard 8200 for 5 years but seemingly goes in and out to my router at least once per day. Looking to replace
Best answer by LoveMyLab
The SB8200 is a pretty good unit. What are you seeing in the event log when it goes out?
From what I see, Mediacom is NOT supporting the Arris S33 or the Moto/Zoom MB8611. So that basically means the SB8200, the Moto/Zoom MB8600 ( I have one and swapped in the SB8200 as part of troubleshooting an issue) or one of the Netgear units. I haven’t worked with Netgear in a long time but would expect their units to work well.
https://mediacomcable.com/assets/pdf/legal/Compatible-Retail-Modems_CRM112022.pdf
LoveMyLab
Guardians of the Gateways
Forum|alt.badge.img+19
  • Guardians of the Gateways
  • 213 replies
  • October 4, 2023
  • October 4, 2023
Thank you
