Recommend Replacement for Arris DG3450?
  • August 3, 2023
  • 435 views
I’m renting an Arris DG3450 modem/router from my internet provider for $13/mo.  Any suggestions on purchasing a replacement?  Should I simply buy another Dg3450 is there an updated version I should consider?  I’m on a 1-gig plan and I use an Eero mesh device to extend reach around the house.
To know more about DG3450 Click the link below:
https://www.commscope.com/globalassets/digizuite/62380-touchstone-dg3450-data-sheet.pdf
For replacement or to buy another DG3450 contact ISP or nearby Vendors
To support the 1Gig plan suggest browsing various products offered by Arris at surfboard.com or shop.surfboard.com
