reset wifi pwd
  • July 7, 2025
  • 55 views
Hello,
Would like to reset the pwd for my wifi
Thanks,
The SB6141 is solely a cable modem and does not have built-in Wi-Fi features. If you are using a separate router, and it is from a third-party brand, you should contact the router manufacturer for assistance with resetting your password.
Could you please help us with your product’s model number?
  • July 9, 2025
Model# SB6141, pn# (Edited personal information), Customer S/N# (Edited personal information)
  • July 16, 2025
Thanks for the update!
