Reseting router and reestablishing SSIDs
  • February 2, 2024
  • 63 views
I need to reset my router. Once done and I reestablish my SSIDs exactly as they were before the reset will my devices automatically recognize them and reconnect since the names are the same and passwords hadn’t changed?
It should. I’ve used the same ssid/password for years and never had an issue. And I switch routers multiple times a year to trial new firmware/devices.
  • February 2, 2024
