SB6121 Firmware
  • August 5, 2024
  • 190 views
Breezeline told me to update the firmware for my SB6121 modem.  I cannot find any source for it on here or anywhere.  Any ideas?
Best answer by LoveMyLab
In general, the ISP controls software updates to connected modems. This is an older DOCSIS 3.0 modem and is no longer supported by Breezeline, so they won’t provide the update. Arris does not provide firmware directly to consumers.
I would recommend migrating to a supported unit. https://www.breezeline.com/assets/documents/2023_approved_modems.pdf
LoveMyLab
Guardians of the Gateways
Forum|alt.badge.img+19
  • Guardians of the Gateways
  • 212 replies
  • August 6, 2024
  • August 7, 2024
Yes, I am aware, thanks.  I found the firmware elsewhere and now it works fine.
