SBG10 not conneted
  • February 7, 2025
  • 24 views
I’m having a hard time getting my router to connect back to my TV. It says that it has a strong signal but is disconnected from the Internet. Not really sure how to get that fixed. I have connected my hotspot to my TV and that works, but even hard wiring Into the modem is not working
  • February 7, 2025
Everything works but the tv?
What router do you have?
What tv is it?
Could you confirm if all other devices, apart from the TV, are properly connected to the network through the gateway and they are working properly?
