SBG6580 factory passcode does not work after hard reset several times...
  • February 8, 2025
  • 100 views
I bought this SBG6580 on ebay and could not get it to work for due to “invalid passcode”.  After hard reset, the default passcode still does not work. How can I get a valid passcode for this to work?
Please ensure that the default network names are broadcasting after the factory reset. To find the default credentials, I would suggest checking the back or bottom of the gateway.
Note: The default Wi-Fi password is case-sensitive, so please make sure to enter it exactly as shown and do not use any spaces while entering the password.
