I bought this SBG6580 on ebay and could not get it to work for due to “invalid passcode”. After hard reset, the default passcode still does not work. How can I get a valid passcode for this to work?
Answer
SBG6580 factory passcode does not work after hard reset several times...
Please ensure that the default network names are broadcasting after the factory reset. To find the default credentials, I would suggest checking the back or bottom of the gateway.
Note: The default Wi-Fi password is case-sensitive, so please make sure to enter it exactly as shown and do not use any spaces while entering the password.
