SBG6700-AC 2.4 GHZ & 5GHZ
  • July 27, 2025
  • 30 views
I have a 5G wifi network and just bought a security camera that does not work on 5G.  It needs to connect to 2.4GHZ.  The back of the box shows that it has “Antenna Configuration MIMO (multiple In, Multiple  Out) for 2x2 on 2.4Ghz and 2x2 on 5.0 GHz,  How do I connect by security camera to th3 2.4GHZ without disrupting the 5.0 GHz for my regular Wifi use.
If the network names haven’t been changed, you can find the default SSIDs printed on the label attached to the gateway. The label clearly indicates both the 2.4GHz and 5GHz SSIDs. Locate the SSID marked as 2.4GHz and ensure it is visible in the list of available networks. Once confirmed, you can proceed to connect the cameras to that network.
