SBG6700-AC loses connection
  • August 9, 2023
  • 59 views
All my  Ring alarm, laptops, Alexa and direct Tv have no connection.  My modem has all the lights on that should be on but the devices don’t connect. This happens about 3 times a day. I have factory reset and have to reset at least three to four times a day. Help please right now we have over 30 devices connected. Just with ring it’s 22
Got a copy of the modem logs and cable connections page? that helps check the connection
  • 2275 replies
  • August 9, 2023
