T25 compatible with optimum
  • September 28, 2023
  • 258 views
is the T25 compatible with Optimum?
TM1602 is the telephony modem. It will work through hardwired  and it supports telephone connection.
If the telephone line is not working, I suggest you to contact your internet service provider for further assistance.
If you looking for Wi-Fi connection, TM1602 is not compatible.
I suggest you to buy svg2482ac. This is Wi-Fi cable modem and it will help you to connect the internet both hardwired, Wi-Fi and telephone support.
T25 is not compatible with Optimum service provider is only compatible with Xfinity.
  • September 30, 2023
Which modem is compatible.  I bought Arris Touchstone TM1602 and it works fine with my tv and internet but not with my phone. Need one that works with all three.
