TM3402a Ethernet Ports non functioning.
I have a TM3402a cable modem. I have my Google mesh WI-FI router plugged into one of the Ethernet ports and it works fine. I would also like to connect my Macintosh via Ethernet, but I am being told that the other Ethernet ports on that modem cannot be used that way. What would be the purpose of 4 Ethernet ports if they are not functional? Thanks
The purpose of it its multiple.
  1. if you have a router that supports wan port aggregation, it can supply greater than 1 gig speeds to a router.
  2. for business class lines, it can connect multiple devices and they have a different public ip address. It allows businesses to have their equipment separate from customers or mixing equipment for security.
@LoveMyLab is exactly correct. Most consumer modems only support 1 public ip address so only 1 device can be connected. There’s a few that support multiple but they’re rare.
LoveMyLab
Guardians of the Gateways
Forum|alt.badge.img+19
  • Guardians of the Gateways
  • 212 replies
  • October 18, 2023
I suspect those are only supported if your ISP supports multiple IP addresses. Your Google mesh typically provides DHCP and only one device on your network can perform that function. I suggest adding a small unmanaged switch AFTER your primary Google router and connecting your Macintosh to that.
The following is directly from Cox:
For modems with four Ethernet ports, only plug devices into Ethernet port one because only one port is active, and additional devices plugged into the other ports will not receive Internet access. Use the access port only for modems with a sticker covering up the extra ports. Do not remove the sticker.
  • 2287 replies
  • October 20, 2023
