I would like to get a new cable modem (Cox compatible) that will support DHCP and port forwarding configurations. I bought the SB6190 not realizing it does not. Wi-Fi is optional. Thanks
What cable modem supports port forwarding?
SB6190 is the cable modem and it doesn't support Wi-Fi and port forwarding configurations.
If you are preferring for port forwarding and DHCP configurations, we recommend you to buy Wi-Fi cable modems such as SBG10, G34, G36 etc.
For more information, visit our official website https://shop.surfboard.com.
