wifi Lights not on Modem
  • 19 September 2022
  • 94 views
The only light on my modem/router which turns on is the power light, The wifi lights do not come on and when Iook at the username “network” it said that it is out of area even though it is in the same room and has always worked previously. Modem/router is Arris Model TG 1682G. Operating system is Windows 11. How can I get internet back and the lights on the modem/router turned on?
Best answer by SURFboard Moderator 30 September 2022, 17:37
Badge +36
Are you able to hardwire a pc/laptop to it and test it?
I dont know. If hardwire you mean ethernet I dont know if this laptop has ethernet, I wrote the laptop company regarding this but they have not responded
Badge +36
What laptop model is it? (look on the label)
ASUS X515
Userlevel 4
Badge +38
Hello,
getting a hardwired connection to check in the web interface if by any reason the WiFi networks are disabled is a good a idea. If this is not possible, doing a Factory Reset to clear any customized information is also good to do.
Please let us know if this helped you.
