Answer
wifi network name and password
  • April 10, 2025
  • 87 views
Hello I have an Arris surfboard SB6141. I do not have the original box. I thought the network name and password was on the bottom of the surfboard but it is not. Can someone help me with this as I have used it to connect at work. Thank you
The SB6141 is just a cable modem and does not include any built-in Wi-Fi features. Therefore, you will need a separate router to connect to the cable modem. The network name and password can be found on the router.
